Incorrect dimensions of exported DWG file from Revit 2016
- Mute
- Permalink
- Report
When trying to export a DWG file from REvit 2016, the dimension values on a broken wall section are showing the incorrect information.
The first image shows the DWG when opened in Autocad after exporting from Revit.
The second image shows what the value should be and what it is in Revit when exporting to DWG.
The DWG value of this dimension changes to the actual measured dimension and not the conceptual dimension taking in account of the break view portion.
