Incorrect Contour Lines
I've been using revit for over five years now, just updated to 2016 from 2014 and this problem is throwing me for loop.
I modelled the site appropiately at the true elevation lines (78', 79', 80', etc.) but somehow when I was relocating my base point to its true location everything (which isnt being referenced by the contour lines). Everything shifted, including the contour lines which I was unaware could be manipulated in such a way.
Basically...
-Contour lines dont match their coorisponding points
I've tried...
-Survey point is at 0'-0".
-Moving the topograhy itself up and/or down to counteract the discrepency.
-Checked the site properties.
-Specified Coordinates.
-Checked the contour line properties, changing between Relative, Basepoint, and survey point.
That being said, I am collaborating with some less experienced Revit users (aka interns) which I think may accidently done something.
I've remodeled the site twice now so this is fairly fustrating and time consuming. Im hoping theres a way to shift the origin of the contour lines but I have not found one so far.
Thanks in advance!
loboarch
Looks like the contour labels got switched to use the "Survey Point" rather than the "Project Base Point".  It is a type property of the contour labels.
Edit:
Well I originally only looked at the first image.  After looking at all of the images you alreay had survey point selected and had the survey point adjusted.  I still think there is some kind of discrepancy with the project basepoint and the survey point causing the problem.  I would have to mess with it to find the issue.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
