Hello I have seen this issue come up a lot on forums but I cant get my head round working out an area for a purge calculation. All I want to do is get an area from some lengths but I get the dreaded message. I understand I need to converted the length to a meters squared? I attached family and screen shot.
Solved by barthbradley. Go to Solution.
Your Purge Ventilation is a Number Parameter, delete it and create an Area parameter.
At first, I thought that you created a number parameter (4.000), then I noticed that the default unit for Area is n.000 as well...
But if I create an Area Parameter and it works just fine.
Sounds like you need a Neutralizer. Divide by (/) or Multiply by (*) will generally work.
Here's some more information on the subject to keep handy:
