In-place mass roof is not converting my mesh into a roof
sarahashiim18
Message 1 of 13
sarahashiim18
I have some issues. My custom In-Place mass shape is not converting into a roof, now it's only a mesh above the waffle slab that I have created. can anybody help me to solve the problem? or teach me another way to create this roof?
ps: I tried to convert it into a wall but it's not working as well.
Replies (12)
Message 2 of 13
In-Place Mass doesn't convert Mass to Roof.  You model the Roof (by Face) on the Surfaces of the Mass.
Site & Massing tab=>Roof by Face
...Finish and close out of In-Place Massing, ignore warning and use the Roof by Face tool to create a roof on each surface of the Mass.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit-M...
Message 3 of 13
sarahashiim18
hello thanks for replying
I guess didn't explain my problem well, I did follow the link you've posted and I've already done those steps to create my roof (roof by face)
the problem is that when I reach this step
  1. Move the cursor to highlight a face.
it's not highlighted, which means I can't select the best to create my roof
but when I choose a model by face - model by wall, I can highlight the roof but again I get an error.
the only thing I can do is model by face - curtain system which is something I don't want to do
Message 4 of 13
If Roof by Face doesn't work, then use Wall by Face.
...you can use a Wall Type that has the same assembly as the Roof Type.
Message 5 of 13
sarahashiim18
Message 6 of 13
Let's take a look at it.  Post the RVT.
Message 7 of 13
sarahashiim18
sure.
thankss in advance 😥
Message 8 of 13
Yeah; it's a booger. I can get there by adding Edges and Profiles to subdivide the Mass.
Message 9 of 13
sarahashiim18
yeah! i've been trying to solve the problem for days. would appreciate it if you could figure out a way to make it happen
Message 10 of 13
Like I said: I can get there (almost) if I subdivide the Mass using Add Edge and Add Profile.
Message 11 of 13
sarahashiim18
I guess I can use this since there is no other solution. would appreciate it if you could share the subdivided revit file with me. thanks!
Message 12 of 13
I just used the Add Edge tool to add a bunch of edges to your form and then staggered placement of Wall by Face and Roof by Face.
Blue = Wall. Pink = Roof.
Message 13 of 13
marc_llistuella_i
it worked for me with this, thanks!
