Since I upgraded to Revit 2022 I don't seem to be able to open my Revit files by simply clicking on them. I get "You'll need a new app to open this .rvt file". Instead I have to open Revit 2022 first, and open the files from there. Is there a way to change that?
Thanks.
Gelöst! Gehe zur Lösung
Gelöst von mariano_biagioli. Gehe zur Lösung
Have you tried this?
Right Click on the file icon > Properties > Open With > Change > and select the desired version.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
It's usually a good idea to open files from within Revit since projects are version specific.
Thank you @mariano_biagioli , at first it didn't work....but ultimately it did!
