In-Place Editor
In-Place Editor
carlov2
Message 1 of 18
In-Place Editor
carlov2
I downloaded Revit 2021 on my macbook with the help of bootcamp and I'm having trouble locating the "In-Place Editor" to "Finish Model", for some reason it's not up in the toolbar.
Replies (17)
Message 2 of 18
Revit LT of Full Revit?
Message 3 of 18
carlov2
I'm not quite sure what you mean with that I'm actually new to the software! Are you referring to which form of Revit I downloaded?
Message 4 of 18
Revit LT does not have In-Place Modeling capability.
My question should have been written: "Revit LT or full Revit?"
Message 5 of 18
carlov2
Full Revit.
Message 6 of 18
Okay, then I'm obviously not understanding the question. Can you elaborate? Maybe provide a screen capture?
Message 7 of 18
Are you saying you can create an in place model but you cannot finish it?
Message 9 of 18
You know, for questions and issues related to the Mac operating systems or Boot Camp, you ought to contact Apple as well.
Message 10 of 18
carlov2
Yes exactly! I am not able to do this, for some reason it isn't showing up in my ribbon.
Message 11 of 18
carlov2
Message 12 of 18
carlov2
rev.PNGHere is my professors screen and as you can tell he has the circled portion whereas I don't, mine is the first picture.
Message 13 of 18
Open keyboard shortcuts, find the command Finish Model and add a shortcut for it.  Then when you don't see the ribbon tool, use the shortcut.
Message 14 of 18
carlov2
How do I open keyboard shortcuts? If I remember correctly it said I had to push windows + D but since I have a Mac I don't have this option.
Message 15 of 18
The "professor" screenshot  is showing the In-Place Contextual Tab. You are not in an In-Place Editing Session from what I see.
Message 16 of 18
carlov2
How do I get to what he is on? I followed the exact same steps that he did.
Message 17 of 18
You are not in the in place family editing mode. You need to select the in place model family, edit in place, then you will see the family editing contextual ribbon.
Message 18 of 18
Follow these instructions to reset the UI.
How to reset the Autodesk Revit ribbon, toolbar, and browser to default settings | Revit Products 20...
Wear protective eye gear and stand a ways back from the computer while dong so.  Report back what happens.
TIP: Extinguish cigarettes before executing.
...a guy in our office named "Wiley" tried. He wasn't so lucky.
