Editar material está inalterável no meu Revit 2021 .
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
joaocastroufba
499 Aufrufe, 5 Antworten
No meu Revit 2021 não consigo editar nenhum material de nenhuma estrutura, simplesmente não mexe. Alguem saberia dizer o que é?
Beschriftungen (1)
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: joaocastroufba
Nachricht 3 von 6
joaocastroufba
als Antwort auf: barthbradley
Fiz exatamente como parece nas imagens porem ao editar cortina de vidro não funciona, nem aparece as demais opções, sabe o que devo fazer?
Nachricht 4 von 6
I don't understand. This is an English-Speaking Forum. I don't speak Portuguese. I used a translator.
Have you unpinned and replaced the Curtain Wall Panel with a Basic Wall Type?   If so, the above workflow should work to change the Structural Material Value of a Structural Wall.
FWIW:  Português - Autodesk Community
Nachricht 5 von 6
joaocastroufba
What I meant is that: I am trying to change properties of the curtain wall (the color of the glass to be more exact) but I am not able to do that because the change options do not appear.
Nachricht 6 von 6
Select and Unpin Panel and look under its Properties for "Material". Change it from there, or change the Panel's existing Material Properties directly through the Material Browser.
