In Dimension text 1/2" or 3/4" size is large ...i want it small just like autocad dimension...
rajashazo
Observer Observer
Message 1 of 8
rajashazo
Observer
Observer
Replies (7)
Message 2 of 8
Alfredo_Medina
Can you please compose your question in a better way? It's not clear.
Message 3 of 8
rajashazo
Observer
Observer
plz find the attached file...hope u understand it
Message 4 of 8
RSomppi
You can assign a different text size to your dimension type just like you can in AutoCAD. Alternatively, you make a new type if the large size is desired and used elsewhere. A common text size for dimensions is 3/32".
Message 5 of 8
Edit: I think you want fraction numbers to be smaller than regular numbers.  That is not possible in Revit.
Disregard this if the above is what you meant:  Write some letters on paper at 1/2" and 3/4" height and you will see they are obviously very large for typical architectural drawings.   Use a smaller text size for your dimension (i.e. 3/32", 7/64", or 1/8").
Message 6 of 8
azad.Nanva
do you mean :
or not?
Message 7 of 8
rajashazo
Observer
Observer
yes sir u pick my point..
Message 8 of 8
azad.Nanva
