Improper use of boolean in Revit 2018.2
Jason_S
Message 1 of 15
Jason_S
I have a parameter Door Rating that if it is filled in with 90 MIN it a tag will read A.
I have this:  IF(Door Rating = "90 MIN", "A", "B")  I am getting the Improper use of a Boolean when I try to hit the OK.
This is a Text parameter.  What am I missing.  Revit 2018.2
Thank you.
Replies (14)
Message 2 of 15
Is Fire Rating a text parameter?  Text parameters don't not work in a formula.  Create another Fire Rating as Integer parameter and use it.
Message 3 of 15
Corsten.Au
Yes.. as @ToanDN mentioned..
here are some samples which works..
Simple IF: =IF (Length < 3000mm, 200mm, 300mm)
IF with a text parameter: =IF (Length > 35', “String1”, “String2”)
IF with logical AND: =IF ( AND (x = 1 , y = 2), 8 , 3 )
IF with logical OR: =IF ( OR ( A = 1 , B = 3 ) , 8 , 3 )
Embedded IF statements: =IF ( Length < 35' , 2' 6" , IF ( Length < 45' , 3' , IF ( Length < 55' , 5' , 8' ) ) )
IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)
Cheers!
Corsten
Building Designer
Message 4 of 15
Viveka_CD
Hi @Jason_S
It's been a while and I'm checking back to see if you were able to make progress on your issue?
Did the suggestions by @Corsten.Au and @ToanDN help resolve your issue?
Please let us know if further assistance is required and if you have any additional questions.
Message 5 of 15
Radish_G
Hi @Corsten.Au,
I got the same message while I key-in the following formula (R 2019.2). Need your guidance.
Regards
Radish G
Message 6 of 15
Corsten.Au
Hello
Make sure all parameters are " Length " parameter.
Example - Unit in Meters
also instance parameters can be calculated from Type but not other way round.
ex
Length (m) - Length(m) = length (m)
Length (m) + Length(m) = length (m)
Length (m) x Length ( m) = Area ( )
Square root of  Area ( ) = Area ( )  ( Example Square root of 49 m² = Area 7m² ( it won't give you length (m)
Area ( ) / 2 ( number/integer ) = Area ( )
Idea is paying attention to " Units" of " Parameters "
Corsten
Building Designer
Message 7 of 15
Radish_G
Hi @Corsten.Au,
Thanks for your reply.
Can help me locate the exact error in my formula?
End Offset (mm)-(Overall Size (mm)/2)
Regards
Radish G
Message 8 of 15
bin
One of the parameters might not be length...
Message 9 of 15
Radish_G
Hi @bin,
Is there any way to identify the type of these system parameters?
Regards
Radish G
Message 10 of 15
Edit the parameter - it will show what category it is.
Message 11 of 15
Radish_G
Hi @Anonymous,
Are we able to do it for the System Family Parameters?
Pipe Family...,
Regards
Radish G
Message 12 of 15
Hi Radish G - yes you can check these also.
If you do not see the category then check that the discipline is set to the correct category.
Message 13 of 15
Radish_G
Hi @Anonymous ,
What I mean is, how to find the type of the existing parameters.
In this case, how to find the type of the "Overall Size" parameter of Pipe Insulation.
Regards
Radish G
Message 14 of 15
If you edit the parameter you can see the type - it will be greyed out though, as it cannot be changed.  If you need a different one you will need to create a new one.
Message 15 of 15
Radish_G
Hi @Anonymous,
This is the place where I am stuck with.
May I have a screenshot of it?
Regards
Radish G
