Message 1 of 9
Importing topo survey data
- Mute
- Permalink
- Report
Hi, problems with Revit again!
I have been given an autoCAD survey drawing with contours shown at the correct elevations.
I have put all the info I want for the toposurface onto one layer and moved the CAD drawing origin to close to the survey data. (To make it easy for Revit!)
The import part of the process went OK but only about 13 points are picked up by Revit when I 'Select Import Instance'. My research suggests that all the contour lines at least should be picked up at some point. As you can see from the above most of the contour lines are either above or below the surface.
Has anyone got "the answer" as to why this is the case?
Many thanks
