Importing Navisworks file into Revit to extract floor plans
smlee0521
smlee0521
I would like to import a Navisworks file into Revit and then generate floor drawings from it. • When creating sections, will they be cut properly? • Will the geometry appear as clean solids, or are there limitations? Has anyone tried this workflow and can share their experience?
RSomppi
Once you trace over it, everything will work as expected.
