Importing DWGs line weights
carl.heintz
carl.heintz
Hi. I am now linking DWGs with quite a large number of layers from 10+ files for the first time and it may be the common practice. I have done this before but with many less layers overall and I went in individually per layer in object styles and modified them. however, this is not very feasible when we have 50 layers or so per file so I was wondering how I can create a rule set for the layers (they are consistent amongst the practices files) so that "X_DrainageToilet" always gets the same line weight when I import it?
I also found the query for linked cad quite clunky when it comes to hatches (it works decently on the lines) so any tips on that would be much appreciated!
You may want to explore this.
carl.heintz
I should have written "line styles", my apologies. Basically as I was trying to get at then we often import 60 layers or so that is (in autocad) controlled with a plot style but when importing into Revit I have to go to object styles to change every single one. I would like to set up a line weight style so that these 60 layers/line styles automatically get transformed to the desired style. Surely that is possible?
