Imported walls
Imported walls
jeanettephann
Imported walls
jeanettephann
Hi all,
I received an existing conditions Revit model and noticed some walls aren't showing up correctly.
When I double click on the wall, the property shows that it's an import symbol. Although they're 3d, they're hollowed out.
Would these walls need to be remodeled as proper walls again or is there a quicker way around this? I just need them to have a black fill and to be consistent with the other walls on plan. Thank you.
Yien_Chao
what kind of importation is it?
can you change the material?
jeanettephann
Not too sure but this is what comes up in the properties.
Yien_Chao
try to override the graphic maybe. if not, I'm afraid you will need to do some remodeling.
jeanettephann
I've tried overriding the graphics, but I suspect since its hollowed out, it won't be able to cut as a 'solid' wall. Thanks for your help though 🙂
What do you say we avoid the guessing game and you just post the RVT here so we can examine it and provide you with a solution?  That's how I would roll.
