imported dwg with layers turned-off shows those layers turned-on on other levels
danezeq
Message 1 of 8
danezeq
1. i turned off some layers on a dwg.
2. imported it to revit. it show ok on ground level.
3. but then i can see those layers i turned off on all other levels on revit.
what the.. ??
Replies (7)
Message 2 of 8
dzanta
when you import a dwg into revit, the visibility settings dialog box controls how the elements in the imported dwg file appear for each view independent of each view.  In other words...
link in the cad file
go to Visibility Graphics
go to Imported Categories
expand the plus symbol of the cad file
turn off/change/hide what you want
click OK to get out of this dialog box
the above steps just changed the visibility of the cad content for that current view.  If you want this to be applicable to other views...create a view template from this view and apply it to the other views....
right click the current view within Project Browser and choose Create View Templates from View
give it a name
click OK in the dialog box that pops up (twice)
change to a different view
right click that view and choose Apply Template Properties
choose the custom view template you just made...click OK
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 3 of 8
Did you check Visible layers only option when import the CAD file?
Message 4 of 8
Sahay_R
And why Import? Linking is the advisable option - also gives better control under the Revit Links tab of the VG / View Template.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 8
danezeq
Now after you suggested to check "visible only", i tried it and it acutually slove the problem.
But what cause this issue anyway? i once again mention that the imorted dwg is shown well (meaning, NOT showing the layers i turned off in autocad) on the view (in revit) that i've imported into it. the problem is on all other revit views.
btw - "visible only" option is shown only when importing, not when linking.
Message 6 of 8
Check that option will not import invisible layers (OFF in AutoCAD).  They are not brought in, period.  So they will not show anywhere.
That also explains why the option is only available for Import, not Link.
Message 7 of 8
danezeq
Thank you i'll do it from now on.
i still wondring if it's a bug, the all thing..
Message 8 of 8
FAIR59
you can delete layers from a linked CAD file. This is semi permanent, when you reload the CAD file, the layers reappear.
