Formula in family creation
12 ANTWORTEN 12
Nachricht 1 von 13
FarhanUddinShaikh
746 Aufrufe, 12 Antworten
Can anyone tell me about how we can use formula(s) in the family creation i-e what are its methods etc
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: FarhanUddinShaikh
Please be more specific about what you want.
Nachricht 3 von 13
Ilic.Andrej
The best place to start learning formulas is here:
https://www.revitforum.org/tutorials-tips-tricks/1046-revit-formulas-everyday-usage.html
Don't forget to read about "Inconsistent Units". The thread covers it.
I assume you know where to put formulas?
Basically, you create multiple parameters and then use them in formulas.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 4 von 13
L.Maas
THIS post on the RevitForum is always good to check what kind of formulas can be used in Revit
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 5 von 13
ThongPN
This post can help you know somethings basic for formula in edit familly
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Nachricht 6 von 13
Sahay_R
Can you give an example of what you are trying to achieve? The formula may be a family parameter, it may be a part of calculation carried out by a label in a tag family, or it may be for a calculated parameter in a schedule. A family that you are attempting to create would be very helpful to provide an appropriate solution.
Rina Sahay
Revit Architecture Certified Professional
Nachricht 7 von 13
FarhanUddinShaikh
als Antwort auf: ToanDN
Just about to know how to use formula section and what are its method , how we can learn formulas i-e how we can formulate two instance property into one element etc
Nachricht 8 von 13
FarhanUddinShaikh
als Antwort auf: Ilic.Andrej
Sorry but link is not opening
Nachricht 9 von 13
FarhanUddinShaikh
als Antwort auf: ThongPN
Nachricht 10 von 13
FarhanUddinShaikh
als Antwort auf: Sahay_R
Nachricht 11 von 13
FarhanUddinShaikh
Nachricht 12 von 13
Sahay_R
FSome formulas that I have added to a sliding door family -
For more information -
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
http://cadshack.blogspot.com/2012/01/revit-family-formula-examples-and.html
Rina Sahay
Nachricht 13 von 13
Formulas are to provide relationships among different parameters.  You need to plan ahead what relationships you need in order to know which formulas to be used.  So be more specific.
Go to the Revit Formula link in my signature.  Your browser may ask you to accept access to an insecure site because Revit Forum site's certificate has expired.
