(Edit: I needed to add some info)
Use this plug-in running on Revit 2015, and then use FormIt (Free) to help with the conversion
Plug-in: http://formit360.autodesk.com/blog/formit-converter/
FormIt: http://formit360.autodesk.com/app
here's what the plug-in does:
- Convert SketchUp SKP files for use within FormIt
- Convert Revit RFA files for use within FormIt. These files maintain their category and identity so that they can be converted back to the proper RFA later.
- Convert FormIt 360 files to RVT and re-place any RFA files from local sources.
So here are the steps fro the cleanest way of getting a SKP into Revit:
- Convert SKP to FormIt using plug in
- Open FormIt
- Insert converted SKP file (now an AXM file) into a FormIt session, using the Library tool
- Save FormIt file (AXM) to A360 Drive (or export AXM locally from FormIt)
- A360 Drive will "cloud convert" AXM to an RVT OR use the Convert Plug-in again in Revit to locally convert an AXM into an RVT
Scott D Davis
Sr AEC Technical Specialist
