Import Sketchup file to Revit
Message 1 of 11
Whats the best 3D file format i can export from Sketchup to import in Revit ?
Replies (10)
Message 2 of 11
when you go to Insert-> Link CAD, you can directly link SketchUp files into Revit.
Doesnt this work correct for you, and therefore you preffer to use another format ?
Assuming you have the Pro version of SketchUp, i guess the FBX works very well for Revit.
Message 3 of 11
Message 4 of 11
Does the fbx work for you ?
Message 5 of 11
scott_d_davis
(Edit: I needed to add some info)
Use this plug-in running on Revit 2015, and then use FormIt (Free) to help with the conversion
Plug-in: http://formit360.autodesk.com/blog/formit-converter/
FormIt: http://formit360.autodesk.com/app
here's what the plug-in does:
  • Convert SketchUp SKP files for use within FormIt
  • Convert Revit RFA files for use within FormIt. These files maintain their category and identity so that they can be converted back to the proper RFA later.
  • Convert FormIt 360 files to RVT and re-place any RFA files from local sources.
So here are the steps fro the cleanest way of getting a SKP into Revit:
  1. Convert SKP to FormIt using plug in
  2. Open FormIt
  3. Insert converted SKP file (now an AXM file) into a FormIt session, using the Library tool
  4. Save FormIt file (AXM) to A360 Drive (or export AXM locally from FormIt)
  5. A360 Drive will "cloud convert" AXM to an RVT OR use the Convert Plug-in again in Revit to locally convert an AXM into an RVT
Scott D Davis
Sr AEC Technical Specialist
Message 6 of 11
When i try to open formlt link it gives me this message
Message 7 of 11
 This plug-in running perfect ty alot dav 😃
Message 8 of 11
Message 9 of 11
Sahay_R
Here's why you get the error message - Revit will directly insert Sketchup8 files. That is why you got the error message. If you open your file in Sketchup and save it back to Sketchup8, you will not need Formit at all. One less step.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 10 of 11
Radish_G
Hi @Sahay_R,
Great it works.
Regards
Radish G
Message 11 of 11
Hi!
Need some help here, I went thru all steps convert SKP to formIt, import FormIt to Revit project, the object appears on the floorplan but nowhere else...not in 3dviews or elevations....what am I doing wrong?  Thanks a lot.
