Import a single view template from another file
DanielKP2Z9V
DanielKP2Z9V
Is it possible to import a single view template from a another project file without downloading all the others? The only builtin tool I could find TransferProjectStandars operates on entire categories and not individual types.
noah_AvatarMetaverse
No, I used to import all the view template in new project then delete all unwanted view template than import only specific view template to my project
DanielKP2Z9V
Thanks, I'm writing a script in C# now to export only selected viewtemplates into a new .rvt file, but got stuck.
DanielKP2Z9V
As per that linked thread above the script is now finished and seems to work fine exporting only the selected view templates to an empty .rvt file (CustomGUI not included - I'll try to open source the full codebase later)
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Collections.Generic;
using System.Linq;
using System.Windows.Forms;
namespace scripts
    [Transaction(TransactionMode.Manual)]
    public class ExportViewTemplatesToRvt : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiApp = commandData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            // Get all view templates in the document
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            List<Autodesk.Revit.DB.View> viewTemplates = collector.OfClass(typeof(Autodesk.Revit.DB.View))
                                                        .Cast<Autodesk.Revit.DB.View>()
                                                        .Where(v => v.IsTemplate)
                                                        .ToList();
            List<string> properties = new List<string> { "Title" };
            var selectedViews = CustomGUIs.DataGrid<Autodesk.Revit.DB.View>(viewTemplates, properties);
            if (selectedViews.Count == 0)
                return Result.Cancelled;
            // Prompt user to choose location and file name
            SaveFileDialog saveFileDialog = new SaveFileDialog();
            saveFileDialog.Filter = "Revit File (*.rvt)|*.rvt";
            saveFileDialog.Title = "Save As";
            saveFileDialog.ShowDialog();
            // Check if the user cancelled the operation
            if (saveFileDialog.FileName == "")
            // Create a new Revit document
            var revitApp = uiApp.Application;
            Document newDoc = revitApp.NewProjectDocument(UnitSystem.Metric);
            // Start a transaction
            using (Transaction transaction = new Transaction(newDoc, "Export View Templates"))
                transaction.Start();
                // Copy the selected elements to the new document
                List<ElementId> copiedIds = new List<ElementId>();
                foreach (Autodesk.Revit.DB.View selectedViewTemplate in selectedViews)
                    CopyPasteOptions copyOptions = new CopyPasteOptions();
                    copyOptions.SetDuplicateTypeNamesHandler(new DuplicateTypesHandler());
                    ElementId copiedId = ElementTransformUtils.CopyElements(doc, new List<ElementId> { selectedViewTemplate.Id }, newDoc, Transform.Identity, copyOptions).FirstOrDefault();
                    copiedIds.Add(copiedId);
                // Commit the transaction
                transaction.Commit();
            // Save the new document as .rvt
            string filePath = saveFileDialog.FileName;
            SaveAsOptions saveAsOptions = new SaveAsOptions { OverwriteExistingFile = true };
            newDoc.SaveAs(filePath, saveAsOptions);
            newDoc.Close(false); // Pass false to indicate that changes should not be saved
            return Result.Succeeded;
DanielKP2Z9V
And for the sake of completeness, the equivalent code to import from that temporary .rvt file (my project browser freezes when I have more than one document opened at the same time in a single revit process, so can't use TransferProjectStandards dialog):
using System.Linq;
namespace scripts
    public class ImportViewTemplatesFromRvt : IExternalCommand
            // Prompt user to select the .rvt file containing view templates
            OpenFileDialog openFileDialog = new OpenFileDialog();
            openFileDialog.Filter = "Revit File (*.rvt)|*.rvt";
            openFileDialog.Title = "Select .rvt File";
            openFileDialog.ShowDialog();
            if (openFileDialog.FileName == "")
            // Open the selected .rvt file
            string filePath = openFileDialog.FileName;
            Document sourceDoc = uiApp.Application.OpenDocumentFile(filePath);
            // Get all view templates from the source document
            FilteredElementCollector collector = new FilteredElementCollector(sourceDoc);
                                                        .ToList();
            if (viewTemplates.Count == 0)
                TaskDialog.Show("No View Templates", "The selected .rvt file does not contain any view templates.");
                return Result.Failed;
            // Select view templates to import
            // Start a transaction to import view templates
            using (Transaction transaction = new Transaction(doc, "Import View Templates"))
                // Copy the selected view templates into the active document
                    ElementTransformUtils.CopyElements(sourceDoc, new List<ElementId> { selectedViewTemplate.Id }, doc, Transform.Identity, copyOptions);
            // Close the source document
            sourceDoc.Close(false); // Pass false to indicate that changes should not be saved
great you can mark this toped as solved, if you already got it works
Simon_Weel
TransferSingle does a decent job.
Transfer Template is free but only transfers templates.
