ModificationOutsideTransactionException when copying ViewTemplates to a new project file
DanielKP2Z9V
DanielKP2Z9V
I'm trying to export selected ViewTemplates (using a custom winform) to a new project file, so they can be imported into another project. However, ElementTransformUtils.CopyElements (line 54) yields a ModificationOutsideTransactionException even though it's wrapped inside a Transaction (line 41).
Does anyone know what may be causing it?
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System.Collections.Generic;
using System.Linq;
using System.Windows.Forms;
namespace scripts
    [Transaction(TransactionMode.Manual)]
    public class ExportViewTemplatesToRvt : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIApplication uiApp = commandData.Application;
            UIDocument uiDoc = uiApp.ActiveUIDocument;
            Document doc = uiDoc.Document;
            // Get all view templates in the document
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            List<Autodesk.Revit.DB.View> viewTemplates = collector.OfClass(typeof(Autodesk.Revit.DB.View))
                                                        .Cast<Autodesk.Revit.DB.View>()
                                                        .Where(v => v.IsTemplate)
                                                        .ToList();
            List<string> properties = new List<string> { "Title" };
            var selectedViews = CustomGUIs.DataGrid<Autodesk.Revit.DB.View>(viewTemplates, properties);
            // Prompt user to choose location and file name
            SaveFileDialog saveFileDialog = new SaveFileDialog();
            saveFileDialog.Filter = "Revit File (*.rvt)|*.rvt";
            saveFileDialog.Title = "Save As";
            saveFileDialog.ShowDialog();
            // Check if the user cancelled the operation
            if (saveFileDialog.FileName == "")
                return Result.Cancelled;
            // Start a transaction
            using (Transaction transaction = new Transaction(doc, "Export View Templates"))
                transaction.Start();
                // Create a new Revit document
                var revitApp = uiApp.Application;
                Document newDoc = revitApp.NewProjectDocument(UnitSystem.Imperial);
                // Copy the selected elements to the new document
                List<ElementId> copiedIds = new List<ElementId>();
                foreach (Autodesk.Revit.DB.View viewTemplate in viewTemplates)
                    CopyPasteOptions copyOptions = new CopyPasteOptions();
                    ElementId copiedId = ElementTransformUtils.CopyElements(doc, new List<ElementId> { viewTemplate.Id }, newDoc, Transform.Identity, copyOptions).FirstOrDefault();
                    copiedIds.Add(copiedId);
                // Save the new document as .rvt
                string filePath = saveFileDialog.FileName;
                SaveAsOptions saveAsOptions = new SaveAsOptions { OverwriteExistingFile = true };
                newDoc.SaveAs(filePath, saveAsOptions);
                // Commit the transaction
                transaction.Commit();
                TaskDialog.Show("Success", "Selected objects have been exported to a new .rvt file.");
            return Result.Succeeded;
Moustafa_K
you have 2 issues with your code.
First, you opened a transaction at the source document, this document you are not going to change, you are just reading the templates, by which you are going to supply to the new Document. Thus, you need to open a transaction from the new Document.
something like this
           using (Transaction transaction = new Transaction(newDoc, "Export View Templates"))
... past your templates
the second issue, you can never save a document before you commit a transaction.
so the steps to follow
1. get all the templates you need
2. create the new document
3. open transaction from the new document
4. past all your templates
5. commit transaction
6. save the the new document
Moustafa Khalil
Cropped-Sharp-Bim-500x125-Autodesk-1
DanielKP2Z9V
thank you, that solved it. the final script seems to have some issues though (copies materials, families and everything else, not just the view template), but that's not related directly to this problem.
DanielKP2Z9V
okay, now it works fine - updated code below. It exports selected view template into a new empty project in reasonable time.
That "copies everything, not just the view template" issue was just a simple omission in foreach loop (line 54 below). I've also added "suppress duplicate types" for convenience from here and close the file handle after it finishes.
using System.Linq;
namespace scripts
                                                        .ToList();
            if (selectedViews.Count == 0)
            Document newDoc = revitApp.NewProjectDocument(UnitSystem.Metric);
                foreach (Autodesk.Revit.DB.View selectedViewTemplate in selectedViews)
                    copyOptions.SetDuplicateTypeNamesHandler(new DuplicateTypesHandler());
                    ElementId copiedId = ElementTransformUtils.CopyElements(doc, new List<ElementId> { selectedViewTemplate.Id }, newDoc, Transform.Identity, copyOptions).FirstOrDefault();
            newDoc.Close(false); // Pass false to indicate that changes should not be saved
Moustafa_K
So glad that you made it work. thanks for sharing your insights
Moustafa Khalil
