Binding different lists to different rows in DataGrid
mizrachi_amir2
mizrachi_amir2
I know this question is more WPF oriented but I am still posting it in this forum.
I am not using MVVM yet and am trying to bind different list to different row in DataGrid.
I have 2 lists:
private List<string> roundProfileTypeNames;
private List<string> rectProfileTypeNames;
and I have a DataGrid as follows:
Each row contains a profile name + a checkbox which is checked if profile is rounded (taken from a parameter in the profile type) + a list of profile types which should be taken from the 2 lists above:
If "Is Rounded Profile" is checked then "Profile Type" should be binded to roundProfileTypeNames list, otherwise (unchecked) it should be binded to rectProfileTypeNames.
Currently, I was only able to bind all rows to the same list (roundProfileTypeNames OR rectProfileTypeNames).
This is my datagrid in xaml file:
<DataGrid Name="profilePropsGrid" Width="500" CanUserReorderColumns="False" HorizontalAlignment="Center" CanUserAddRows="False" VerticalAlignment="Top" AutoGenerateColumns="False">
    <DataGrid.Columns>
        <DataGridTextColumn Header="Profile Name" Width="*" Binding="{Binding ProfileName, Mode=TwoWay}" IsReadOnly="true" />
        <DataGridTemplateColumn Header="Is Rounded Profile?" Width="*">
            <DataGridTemplateColumn.CellTemplate>
                <DataTemplate>
                    <CheckBox IsChecked="{Binding IsRound}" Checked="IsRoundChecked" Unchecked="IsRoundUnchecked" />
                </DataTemplate>
            </DataGridTemplateColumn.CellTemplate>
        </DataGridTemplateColumn>
        <DataGridComboBoxColumn Width="100" Header="Profile Type" x:Name="ProfileType"
             SelectedValueBinding="{Binding ProfileType, Mode=TwoWay}"
            DisplayMemberPath="{Binding ProfileType}" />
    </DataGrid.Columns>
</DataGrid>
And this is a snippet from my xaml.cs file:
bridgeProfileList = new List<ProfileItem>();
foreach (Element elem in framingPipeTypesCol) // Iterating through all framing pipe types in Revit
    ProfileItem ep = new ProfileItem()
        ProfileName = elem.Name,
        ProfileElement = elem
    IList<Parameter> pipe_shape_circle = elem.GetParameters("Pipe Shape_Circle");
    if (pipe_shape_circle.Count > 0)
        int pipe_shape = pipe_shape_circle[0].AsInteger();
        if (pipe_shape == 0)
            ep.IsRound = false;
            //ProfileType.ItemsSource = rectProfileTypeNames;
        if (pipe_shape == 1)
            ep.IsRound = true;
            //ProfileType.ItemsSource = roundProfileTypeNames;
    bridgeProfileList.Add(ep);
    Debug.WriteLine(elem.Name);
profilePropsGrid.ItemsSource = bridgeProfileList;
How can I bind the correct list if checkbox is checked/unchecked?
Thank you!
jeremy_tammik
I don't know WPF myself, so I asked Meta AI for you. It replies:
To achieve this, you can create a property in your ProfileItem class that returns the correct list based on the IsRound property. Here's an example:
In your ProfileItem class, add a property like this:
C#
public List<string> ProfileTypeList
    get { return IsRound ? roundProfileTypeNames : rectProfileTypeNames; }
Then, in your XAML, bind the ItemsSource of the DataGridComboBoxColumn to this new property:
Xaml
    ItemsSource="{Binding ProfileTypeList}"
This way, when the IsRound property changes, the ProfileTypeList property will return the correct list, and the DataGridComboBoxColumn will update its items accordingly.
Note that I assume roundProfileTypeNames and rectProfileTypeNames are already defined and populated in your code. If not, you'll need to make sure they are properly initialized and accessible.
Does that help?
mizrachi_amir2
I did the same, here is how my ProfileItem class looks like (there are many rows below of initializing the 2 lists):
internal class ProfileItem
    public string ProfileName { get; set; }
    public bool IsRound { get; set; }
    public string ProfileType { get; set; }
    public Element ProfileElement { get; set; }
    public List<string> rectProfileTypeNames = new List<string>();
    public List<string> roundProfileTypeNames = new List<string>();
    public ProfileItem(string name, Element elem)
        this.ProfileName = name;
        this.ProfileElement = elem;
        rectProfileTypeNames.Add("RHS 50x30 / 2.6");
        rectProfileTypeNames.Add("RHS 50x30 / 3.2");
        rectProfileTypeNames.Add("RHS 50x30 / 4");
        rectProfileTypeNames.Add("RHS 50x30 / 5");
I also add ItemsSource="{Binding ProfileTypeList}" to my xaml file:
    <DataGrid.Columns>
        <DataGridTextColumn Header="Profile Name" Width="*" Binding="{Binding ProfileName}" IsReadOnly="true" />
        <DataGridTemplateColumn Header="Is Rounded Profile?" Width="*" >
                <DataTemplate>
                    <CheckBox IsChecked="{Binding Path=IsRound}" Checked="IsRoundChecked" Unchecked="IsRoundUnchecked" />
                </DataTemplate>
             SelectedValueBinding="{Binding Path=ProfileType}"
    </DataGrid.Columns>
</DataGrid>
But now my ProfileType column shows me empty lists in all DataGrid rows:
I can see in my ProfileItem class that ProfileTypeList shows "0 references":
I think that the binding doesn't take place. Isn't it?
