Import .3dm (Rhino 3D) drawing curves
3 REPLIES 3
ynasonov
237 Views, 3 Replies
When I import a 3dm file I can see surfaces and solids, but not lines. Is curves and annotations import even supported by Revit?
Tags (3)
Labels (1)
3 REPLIES 3
syman2000
in reply to: ynasonov
I would export it as DWG and it will show your text and lines
ynasonov
in reply to: syman2000
Thank you, syman2000
Yes I know that it could be done by exporting to dwg in Rhino, just wanted to confirm that Revit can not load properly nor curves not annotations from 3dm files🤷‍:male_sign:.
syman2000
Revit only import 3d geometry from Rhino and not the annotation, 2d lines, arc and spline.
