Import 3D Furniture into Revit
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am relatively new to Revit. I have read and tried to follow the procedures recommended for other users who have had similar issues with manufacturer furniture models but without success. I want to be able to import a manufacturer's furniture model into Revit and apply materials to the legs, frame, and seat separately. When I open the dwg directly in AutoCAD 2024, the geometry of the model looks as it should. When I open the dwg in 3ds Max, the geometry of the edges meet improperly. When I link the dwg / CAD directly into Revit, it does not look right (frame and one level of the seat are missing) and this error occurs: "Revit cannot import some of the geometry. This result can be caused by various issues with the source file. Adjust the geometry in the file and try the import process again." When I insert the dwg / CAD into a Revit family, the model again has missing parts and does not appear when i load it into a Revit project file. Ideas? File is attached. Thank you for your time.
