implementation of position tracking for VR/AR solution for Revit
hope someone can tell me if its  possible to implement live position data from  a tracking system into Revit model. Usecase is to go somewhere in the building,  put on VR or AR Headmount and automatically the current position is set to the  Position in the revit  model.
Tanks for your  help and Sorry for my Bad english.
Best  greetings  from Germany
L.Maas
Not sure if it is possible. But normally you would use different software to do this.
For example you can look at Revit Live, Enscape, Unity, Unreal and so on.
Louis
Please mention Revit version, especially when uploading Revit files.
Autodesk a push button Revit to VR application called Autodesk LIVEOops, forgot about the new branding.  It's called Revit Live now. @L.Maas is on top of it!  Smiley Wink
https://www.aecmag.com/technology-mainmenu-35/1255-review-from-revit-to-vr
