Image Shifts during printing pdf in Revit, since at least 2020 version
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My problem is similar or exactly the same to the one described here:
Every time I print the site plan to pdf the background raster map.jpg is slightly shifted so that revit site boundary doesn't match the one on the raster file. Everything lines up perfectly in Revit.
The problem occurs in every Revit version - the file was created in 2015 and it still exists in 2020.
The problem occurs with most pdf printers - PDF Creator, CutePDF, PDF Architect. It doesn't occur in Microsoft Print to PDF but setting up a print size of A2 is such a hassle that I stopped before i broke something
Even more frustrating - a college suggested to shift the jpg background in Revit so it doesn't line up there but the printed pdf will be fine. Nope. The jpg seems to rotate whole degrees incrementally so shifting to the left or right will always result in the site boundary being off to the left or right - e.g. if you shift the image 0.1 degree to the left: on the print it will be shifted 1 degree to the left regardless.
See the attached picture.
I'm out of ideas. I can't print this correctly as a pdf at all.
PS. This also occurs with other file but the error is smaller with smaller sites. Here the plot is 200 m long.
