Image Parameter in Door Family
danielc4
Observer Observer
danielc4
Observer
Observer
I added an image to a door family that will be reflected in a door schedule. The image was attached to the "Image" parameter within the door family itself. I have added that Image parameter into the schedule, and all works perfectly. The image associated with that door shows up fine within the schedule.
The problem I am having is when I close the file and try to reopen. The file will give me an error that says "A serious error has occurred. The current action has been canceled." The file will not open. After a lot of trouble shooting, I figured out that it has to do with the image being attached to a door family. It works with the window families and schedules, and lets me close and reopen the file just fine. But when I add an image to a door family, save and close. The file will not reopen. I have tried different door families, I even created a new door from scratch. I tried using project parameters vs family parameters, all with the same result.
Has anyone else ran into this problem?
Weird. Post the problem Door Family and Image File here for us to test and troubleshoot.
Add the image directly to the schedule as an instance parameter.
