IFC not working
IFC not working
Eduard_KmetVJTPS
IFC not working
Eduard_KmetVJTPS
Hello, today I encountered a problem with an IFC file. When I open the file in programs like BimVision or even through Autodesk Viewer, the elements in the IFC display nicely. However, I wanted to load the IFC into Revit and it doesn't display there. When I link it, only an empty floor plan remains, and when I open it (OPEN - IFC), it gives me a message that no building elements are found in the file. Could someone advise me where the problem might be?
Basam.Yousif
You have a marker on the 0,0,0 point that is somehow getting exported along with the file. This caused the file to be too large (for zoom extents) and most programs, including mighty AutoCAD and C3D struggled with reading it.
You will have to hide those origin markers or crop out the view. It seems you have many of these things. 135!
The DWG is attached.
