IFC model to Revit
10 REPLIES 10
Message 1 of 11
ORISON-AUTODESK
1005 Views, 10 Replies
IFC model to Revit
ORISON-AUTODESK
Hello everybody,
I have made a 3d model from scratch and wrote it to an IFC file. Now when importing this model, I  have a problem with my family structure. The problem  is that each element gets its own family ( for example basic wall 54897 ) instead of the element going into the family of basic wall.
I have tried to alter the structure of the IFC fill but so far no luck. Where in the IFC file is it determined to which family the wall belongs? And a sidequestion: Is it able to alter the family of this basic walls? Or is IFC not changeable in this regard to Revit?
Kind regards,
Andreas
IFC model to Revit
Hello everybody,
Kind regards,
Andreas
Labels (4)
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ORISON-AUTODESK
How did You create this IFC file? In which software?
Can You post this example IFC?
Rafal Gaweda
Hi @ORISON-AUTODESK
Rafal Gaweda
Message 3 of 11
ORISON-AUTODESK
I do the conversion to IFC of the file in FME.
I uploaded a test IFC.
Message 4 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ORISON-AUTODESK
Unfortunately You uploaded RVT file instead.
Rafal Gaweda
Hi @ORISON-AUTODESK
Rafal Gaweda
Message 5 of 11
ORISON-AUTODESK
Hey @Rafal.Gaweda
It didn't allow me to upload a file with the ifc extension. So i uploaded the .rvt file.
I have now uploaded the ifc file as a .txt file.
Hope this is a good way to go.
Kind regards,
Andreas
Hey @Rafal.Gaweda
Kind regards,
Andreas
Message 6 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ORISON-AUTODESK
I am afraid it has been exported like that from Bricscad.
See below
Rafal Gaweda
Hi @ORISON-AUTODESK
See below
Rafal Gaweda
Message 7 of 11
ORISON-AUTODESK
Hey @Rafal.Gaweda ,
When I import my model from FME directly (see attachment) I do get the same error. So not bricscad?
Any idea where in the conversion this is happening?
Hey @Rafal.Gaweda ,
Message 8 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ORISON-AUTODESK
The latest file is corrupt.
Please check Your IFC files inSolibri
Rafal Gaweda
Hi @ORISON-AUTODESK
Rafal Gaweda
Message 9 of 11
ORISON-AUTODESK
Hello, @Rafal.Gaweda
Did a quick check on my IFC file, apparently something was going wrong with IFC4. I already opened this file in Solibri
 to check if there were any errors.
In attachment the same file but in IFC2X3
Hope we can finally work on solving the question after this hiccups.
Message 10 of 11
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @ORISON-AUTODESK
I do not see any correct object in this file
Rafal Gaweda
Hi @ORISON-AUTODESK
Rafal Gaweda
Message 11 of 11
ORISON-AUTODESK
Hey @Rafal.Gaweda
I was out due some sickness so sorry for the late reply. Do you have any idea why the exported objects aren't correct?
Kind regards,
Andreas
Hey @Rafal.Gaweda
Kind regards,
Andreas
