IFC linked file is missing when uploading revit file to autodesk viewer
I have uploaded a Revit file to the autodesk viewer environment. This Revit file contains an linked ifc file. When uploading the file to the autodesk viewer environment it is asked to upload also linked files, so i have uploaded them to. But after processing the files I got a messsage  "Revit-MissingLink Missing link files: name of the missing file"
Has anybody experienced this problem and has an solution for me?
Thanks in advance
Link Path set to Relative?
Yes, relative
ejnar
Observer
Observer
I have the same problem.
But it should not matter if its relative or absolute, because you are asked to upload the linked files separately.
It should then just couple those linked files directly, right?
Kev_D
Any update on this. I have the same issue. All files are located in the one folder and uploaded together. I set the Arch file to Parent, and then 3 other Consultant files to children.
z_bouragbi_
Any update on this please ? i have the same probleme !
