IFC Import Not Aligning to Survey Point
I'm looking for some help with import IFC files from Archicad, and aligning with the Survey Point and Local Base Point.
In Archicad I configure the Survey Point to align with 0,0 of the surveyors DWG file. In this simplified instance is 20m West and 10m South of the Project Base Point in Archicad.
I then setup a new Revit file and in Manage>Corordinates> Specificy Co-ordinates at Point, I click the Project Base Point (and Internal Origin) and enter Easting: 20,000mm Northing: 10,000mm N. Giving me the following, which matches with Archicad.
I then go Insert>Link IFC and select the IFC exported out of Archicad.
After it finishes processing, I am left with the below, which aligns the Archicad Survey point with the Revit Project Base Point, which is not correct.
Interestingly. If I open the .IFC.RVT file created as part of the IFC linking, the Survey Point, Project Base Point and Internal Origin are all sitting at the same spot at 0,0.
However, if go File>Open>IFC and open the IFC file directly, it shows the Survey Point in the correct location relative tot he Local Base Point and Internal Origin.
What I am I doing wrong when I link the IFC into Revit?
Sample IFC File attached for reference.
Scott
