IFC file with simple IfcRevolveAreaSolid not displayed in Revit and Solibri
I have a small IFC file which has simple IfcRevolveAreaSolid with default placement of profile along XYZ axes and global Origin.Profile is a polyline with 5 points, a square in XY plane. Axis of revolution along Y-Axis. This is not displayed properly in Revit. Its showing gaps between profile and the surface.
Solibri its not at all shown.  And if i offset the axis along x-axis a bit. Its showing weird results.
Can any one explain these behavior.
Pls find attached file.
Anil
ryan
Hi, you're better off posting your IFC/Revit question here: https://sourceforge.net/p/ifcexporter/discussion/general/
