IFC file exported from Archicad to Revit, some elements are missing.
Message 1 of 10
Hi everyone,
So one of my colleagues uses Archicad and they designed a topography  model in it, and they exported a IFC file.
However the geometric lines are not correct, its all triangular form. So basically the contour lines are not correct, so is there any way to fix that? I've attached a image below to help understand my circumstance.
Replies (9)
Message 2 of 10
Sounds like you are referring to this setting is Visibility and Graphics Overrides
VGTriangulation.png;
Yours may be checked
Message 3 of 10
Yeah, i tried that option but it's already unticked before i even could untick that option
Message 4 of 10
May I see what you are referring to? A picture is worth a thousand words.
Message 5 of 10
Sure, here it is
Message 6 of 10
Ask him to export the top to DWG instead, then link it in Revit and create the topography surface from import.
Message 7 of 10
Pretty ugly.  Let's try post the actual IFC.
Message 8 of 10
This is the original IFC file i've trying to work on in revit
Message 9 of 10
@Anonymous: Here's first draft. I can't work with little more tomorrow for you. It's getting late here.  Give me some feedback.
Message 10 of 10
This is great, legit can't thank you enough! Really appreciate it!
