IFC EXPORT - Missing windows & doors
Marcus.Isacsson
Marcus.Isacsson
Hi fellas!
We just recently started having problems when exporting to IFC.
Our windows & doors are embedded into the walls, in Revit it all looks as it should though.
Does anyone have a solution?
Pics below:
RDAOU
@Marcus.Isacsson
Can be several reasons but looking at the adjacent buildings, windows seem to be exporting fine there...
  • are your walls joined walls? or 1 wall element?
  • The opening in the window family is an extrusion? a nested void family or a Wall opening?
  • Did you try to export the Main building and the existing surrounding as separate IFCs
syman2000
What setting did you use when you export IFC from Revit? I did encounter when I export IFC from Revit, any wall opening or curtainwall will export as solid object. I did have success using ArchiCAD IFC export from Revit. Check the plugin
https://graphisoft.com/downloads/interoperability
Marcus.Isacsson
Solved!
It seems that the latest IFC exporter has some weird bugs, installing an older version seems to work!
