IFC export error from model text
theBIMengineers_Kai-Wing
I'm trying to export a model with a model text in it. This gives me an error while exporting. After I tried to unpin or modify the text, but i get another error (A serious error has occured. It's strongly recommended that you use Save As to save your work in a new file before continuing).  Also I already tried audit the model, but still get the same errors. Anyone got an idee how this can be solved?
Revit version: 2020.4
IFC exporter: v.20.3.2.0
IFC export option: Extra low detail
With kind regards,
Kai-Wing
alan_eu
Hi @theBIMengineers_Kai-Wing
Thy to click on open button, mark the audit option and select your file. Many times this audit button can save us!
Also, try to disable your graphic card at OPTIONS / HARDWARE and restart your Revit.
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
Already tried both of the option, but non of it worked. Anyway thanks for the tip.
