Would someone please advise how to achieve CAD export from Revit 2020 which would retain linework changes I have made?
I need to make some lines invisible and some hidden.
This shows fine on the Revit sheet.
After export to CAD, there are no linework changes retained in the CAD, all is reverted.
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
I believe invisible lines applied using Linework are considered overrides...Check your DWG export settings and make try to export Overrides by entity
Revit Left - DWG Right
Make sure you override using the system <Invisible Lines> line style, not a user-created InViSiBle lines with a white color.
yes, I have used the correct LW invisible line.
anyone else working on the same project does not have this problem. the sheets are exporting for them ok.
@Anonymous
Which should tell you that the issue is in the Export Settings on your workstation (as mentioned above)...
thank you.
from what we have seen all settings are the same, but we have not tried to go to other and then back to BS. Hopefully it will work when we test this on Monday.
I am not sure what are the modifiers are that would be machine specific and not project specific. could you please be more specific?
