If Yes/No parameter = Yes, then text parameter = 'Remark X'
jnoordzij
jnoordzij
I have a yes/no boolean parameter called 'With Connector'.
Now I want to have a connection with another parameter as follows: If "With Connector' = Yes, then I want another parameter called 'Remark' ( a text parameter) to say 'With Connector'.
So I was thinking to use an 'if' formula in the following way:
if(With Connector = Yes, (then) 'With Connector', (if not) 'Without Connector')
...But its not working.
Is it possible to make a connection this way between a boolean yes/no and a text parameter?
christopher_holden
Yes, the syntax you require for your text parameter formula is:
if(With Connector, "With Connector", "Without Connector")
A Revit yes/no parameter behaves like a boolean variable = true/false.
if(With Connector, "With Connector", " ")
