IF condition based on label (family selection) parameter
1 REPLY 1
denisyukJ
304 Views, 1 Reply
Hello everyone,
I want to make realtion based on selected family type (label parameter in family creator). I understand the logic, but can't realize that and find information in knowledge database.
At the pic below i breefly describe what i am talking about, but this syntax doesn't work.
Sample file in attached. Revit 2021.
1 REPLY 1
RDAOU
in reply to: denisyukJ
@denisyukJ
You need 3 Family Type Parameters (T1, T2, T3)  to serve as a dictionary (1 for each cube type)...
then you set the If statement based on FamilySelection matching each of the above parameters
if(FamilySelection = T1, 100 mm, if(FamilySelection = T2, 200 mm, if(FamilySelection = T3, 300 mm, 0 mm)))
