Identity Data Parameter
I can see certain Identity Data parameters inside the properties window that i can't see when I go to the family property window. How can I add a parameter so that it shows on both?
I have attached an image for your reference. Thank you in advance for your help!
Ivan
They are there by default. Perhaps you need to expand the Identity Data category.
When you click on a family in Revit....the parameters you see in the Properties Window are the Instance Parameters....when you click Properties you get a list of all the type properties.  So different families are going to have different options...and it depends on who built the family and what category they assigned the parameters to.
Suggestion....don't try to over analyse all the parameters in a family....it will drive you nuts.
