I want one wall, I see two
marco.morazzini86
Message 1 of 10
marco.morazzini86
When I create a wall, why does this wall appear split automatically? After a certain length, the wall is considered a single element but this appears divided into 2 with a small empty space between them. I think this should be for a kind of structural joint but, what should I do if I do not need that?
Thanks for your help
Marco
Replies (9)
Message 2 of 10
martijn_pater
Share a screenshot. Don't know what you're looking at, possibly a curtain wall... hard to tell.
Message 3 of 10
marco.morazzini86
What you see is generated automatically, although Revit sees it as just one wallCattura.PNG
Message 4 of 10
martijn_pater
Could be caused by intersecting (hidden) geometry, maybe check reveal hidden elements (also check 3d)...
Message 5 of 10
marco.morazzini86
I checked and there is no hidden geometry.
Message 6 of 10
martijn_pater
It could also be intersecting geometry set in a different phase.
Message 7 of 10
There is a wall there in a different phase.
Message 8 of 10
nmarcelis
You're spot on, Phasing is often the last thing people check when things are not working like they should or have visibility issues.
Revit Certified Professional Architecture, Structure and MEP.
Message 9 of 10
syman2000
Set the phase filter to none and see if there is object hidden there.
As well click on reveal all to reveal object hidden by element
Message 10 of 10
martijn_pater
Like I said, intersecting geometry in a different phase. It is caused by join behavior over different phases.
FWIW:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
