I NEED HELP with my mass walls and the original walls
Message 1 of 21
So i have a small problem connecting an (Interior Original Walls End) with a (Mass Sloped Exterior Wall) or a (diagonal wall)
Pictures Describing my problem...
Replies (20)
Message 2 of 21
Use Join geometry.
Message 3 of 21
What do you mean by "Mass Sloped Exterior Wall"?  You mean a Wall by [Mass] Face?  What it looks like to me is that the circled Walls are actually higher than the surface they are in contact with.  Maybe posting your file would be best -- unless of course Joining did it for you.
Message 4 of 21
dferreira-blackwell
your orignial walls are sloped while mass ones are not.
Message 5 of 21
Actually, I don't think it's walls we're looking at.  It looks reminiscent of refrigerator artwork done by my kids when they were in kindergarten.   Ah...precious memories.
Message 6 of 21
dferreira-blackwell
he..he..neat.!
Message 7 of 21
dferreira-blackwell
share the walls in a new project if possible
Message 8 of 21
I've tried the join geometry command but, it does not do anything..
Message 9 of 21
i made a fast sketch to help you understand my problem, and sorry for the delayed replay
as you can see it's a section sketch, and the interior wall are in elevation
i hope you understand
Message 10 of 21
dferreira-blackwell
do edit profile to set edges of the wall as you want.
Message 11 of 21
actually the internet connection is so wack in here, i can't upload anything but pictures..
I've replayed to barthbradley
with a section sketch of my problem and what i want to achieve, please look it up.
Message 12 of 21
dferreira-blackwell
well, try to upload walls, cause otherwise, I cannot do anything just by assuming.
Message 13 of 21
is there any other way to do that, because i've got almost 100 walls like that
if there is an efficient way to accomplish that, i will be pleased..
Message 14 of 21
ok, i'll try to upload them.
Message 15 of 21
dferreira-blackwell
well, they are sloped so you have to edit profile, its the only easy way I can think off, but ask @Anonymous, he probably has innovative idea.
Message 16 of 21
You just need to extend the interior walls to pass the edge of the exterior wall, then create an in place model with a void or with a cut opening to trim the interior walls to match the edge of the exterior wall.
Message 17 of 21
that took a while to upload..
here it is >> walls
Message 18 of 21
thanks for replying
i will try that
Message 19 of 21
thanks a lot, That helped a lot, but it's a little bit tricky when i try to cut the other walls when the void Disappears after the first cut, but still better than editing all the walls.
Thaaaaaanks.😁
Message 20 of 21
Use Multiple Cut so that you can cut all the walls at once.
