I need help with massing in site in revit
mtb219
mtb219
Im trying to create a mass so I can make a shading roofing system in between the two structural elements on the left and right what do you think the best method to create this prametric/organic shape i have a submition tmrw so I really need the help.sdasa.PNG
  • Help
d.ahmed.LW
Have you tried doing this with Dynamo? It is indeed a bit last minute and if you have no experience with Dynamo, one night might not be enough. 😞
mtb219
I'm not familiar with dynamo unfortunately, but I used spline through points in the in place mass in massing & site and it worked like a sharm 😀. But I will look into dynamo because right now im switching between rhino, sketchup and revit to make some parametric geometry. Thank you!
d.ahmed.LW
@mtb219 that is great that you found the solution yourself. Hope the submission goes fine. Dont forget to close the topic by marking your answer as solution
If you're interested in a faster and easier way, post your file so I can try something.
Community Visitor
Community Visitor
can you send me the file
