Can't add fascia to roof
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
gyn573
454 Aufrufe, 5 Antworten
So I'm able to add a fascia to the front (section of town home with front door) and back of the roof, however I'm not able to add any to the sides. Even when I hover over the roof it won't let me select it. The sides are sloped. Any help would be greatly appreciated!
5 ANTWORTEN 5
Nachricht 2 von 6
gyn573
als Antwort auf: gyn573
I solved it
Nachricht 3 von 6
Mike.FORM
please post how you solved it so others can use what you learned.
Nachricht 4 von 6
als Antwort auf: Mike.FORM
I'm betting the actual edge wasn't visible in the view. That is, the edge was clipped by a crop boundary or Section Box.
But then again, I betted on Eagles.  :zwinkerndes_Gesicht:
Nachricht 5 von 6
Mike.FORM
als Antwort auf: barthbradley
Yeah likely the case. I have made that mistake too with the elevation cut just clipping the overhang and not realizing as it almost identical if you don't have cut patterns visible in elevation.
I also was betting on the eagles. If there was just one more score it would have been the highest scoring Super Bowl ever. Current record is 75 points in Super Bowl 29 (Chargers v 49ers with 49ers winning 49-26). This one ended up at 73 points (38-35).
Nachricht 6 von 6
gyn573
That's exactly what I did, but instead of trying to add the fascia on 3D view I tried to add it on the roof top view which worked. Still couldn't see it in 3D so made a section cut and bam, it was there. That's when I realized it was cropped out of view on 3D so definitely a silly moment but at least last nights game was a fun one to watch
