I need to export this file to SketchUp but me Revit version is 2018 and I can't go with the IFC solution because I'll ruin all the materials and components and will export only faces.
http://www.mediafire.com/file/0g0j3avntlocz03/Barranca_Este_No._92_3D.rvt/file
Solved by aRcHiTeCt.JM. Go to Solution.
.... here it is in IFC
... your project is too heavy
... do you know how to link ... you can divide it in landscape, architectural, interior, etc...
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
..... CONGRATULATIONS @Anonymous
... the level of detail in your project is awesome !!
.... I really like it !!
aRcHiTeCt.JM
REVIT EXPERT ELITE
Hi @Anonymous
Please see the article on how to Import SketchUp Files and check out the video below.
Hope that helps!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Likes welcome!
Thank you!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
i'm pretty sure this website you are using to share your file is known to contain viruses & malware
do you not have access to another cloud sharing service like dropbox, google drive or one drive?
DarrenP
Hi @Anonymous
I'm checking back on this post.
Did the resolutions in the above posts help with your issue?
Do you seek more assistance?
Viveka CD
