I need a phone number to cal
Is there a phone number I can call to get help installing revit
these are the support options: http://www.autodesk.com/subscription/technical-support
which one was bought with the software?
have you tried contacting a reseller in your area for help?
if your on active subscription you can create cases directly with autodesk by logging on to your autodesk account: http://knowledge.autodesk.com/customer-service/account-management/subscription-management/support-op...
matthew.d
Hi @Anonymous,
To add on to what @Anonymous said, you can also submit a case to request assistance. However, what seems to be happening when you try to install?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
Okay, I was able to get revit to install, however, now there are no families associate such as wall types like exterior brick-cmu for me to install on my walls, same for doors.Did I miss something in the intstallation?ThanksDeb
sureshchotrani
Wellcome to the community:)
Actually wall are the system families, they need not to be loaded. They are there in the template file.
For creating other types of wall you need to duplicate the one already there and modify as per your requirement, see here
However for doors there are families in Revit content library. If this is not installed kindly follow steps here
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Autodesk support does not answer support requests. I reached out weeks ago and have received no response.
matthew.d
Hi @Anonymous,
Apologies for the issue again. I have responded to your other post here.
Matt DiMichele
