i have a problem importing a CAD file
i made a CAD file with a point cloud(.xyz) file
and then imported to Revit 2014.
however, such warning comes up like below figure.
how can i solve this problem ??
Any advice is greately appreciated.
Thanks !!
Thanks !!
What are your visibility/graphic settings on the Imported Categories tab? Did you link it with "Current view only" checked or unchecked? Are the extents of the CAD file more than 2 miles from the origin? Did you link it center-to-center, origin-to-origin, etc? Did you double-check that the view wasn't cropped?
Need more info.
Need more info.
thanks for your advice.
I figured it out that there was a problem in setting the options in visibilty setting.
I think the the CAD was far from the origin
but I still can understand the options well.
how could I check the options if I want to work the revit
in the position of my CAD file?
this is the problem!!
I want to concide the left bottom point(project base point) with right upper point(CAD file)
