I want to edit this parameter to just show the date, not the time
How do I go about doing this
Aidan
Solved by barthbradley. Go to Solution.
Revit timestamp uses Windows short date and time format. Edit it under Windows settings.
Thianks I was able to access windows settings and see the changes
But what if I want to get rid of the time stamp, I dont think it allows me in windows settings
Aidan
What about just replacing it with another label like "Sheet Issue Date"? I don't know if I would monkey around with system settings myself.
What about covering the time with a Solid White Filled Region Generic Annotation Family (e.g. a Symbol)?
This was my first thought.
I will try it - but should this be done in the titleblock or in the project?
If you don't want to change Windows settings then create a 254 254 254 opaque text style and place a piece of text over the time to mask it in the title block family.
