I have 12 lights in this small room and none of them are rendering. Why?
winstonfoxnelson
Message 1 of 11
winstonfoxnelson
The bookcase has 3 nested lights in it, two of which are undercabinet lights which I've cranked up the intensity on. All the other lights are stock. I'm at my wit's end. Thanks for your help! Project attached.
Replies (10)
Message 2 of 11
Secttor
Hi @winstonfoxnelson
You've saved your project in an earlier version of Revit, probably 2018 so cannot saw it. Il also depends which settings are used in the render dialog (clouds?) and also to be sure the light-source is not inside a geometry.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 3 of 11
winstonfoxnelson
Yeah it's 2018, sorry about that.
I have a wide variety of lights including floor lamps, ceiling lights, and
wall lights. The render setting are such that it's interior artificial
only, all the lights are on and the dimming setting is set to 1 (no
dimming). I've tried turning the light exposure all the way up, shadows all
the way down, etc. The render shows totally black.
Message 4 of 11
aRcHiTeCt.JM
..... hi
.... what you need to do is to tweak these settings
... and lower the intensity of the cabinet lights
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 5 of 11
winstonfoxnelson
What the heck? This is driving me crazy. I have just done another rendering using the same settings you had, and adjusted to the exact same number you have, clicked "apply", and it's still black. Could it be that there's some other setting within Revit that is incorrect on my end?
Message 6 of 11
aRcHiTeCt.JM
... let's try this:
... go to your plan view
... create a new 3dview and try to render it with the settings I just said before
....let me know....
.... or maybe try moving forward your camera...
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 7 of 11
Make sure your camera is not burried inside a wall.
Message 8 of 11
winstonfoxnelson
Somehow, the camera was in the wall, even though in the 3D view it didn't appear to be so. How bizarre! Anyway thanks for your help.
Message 9 of 11
@winstonfoxnelson
Another thing: You need to Share your Light Fixtures that are nested inside your Bookcase Family. If you notice, they aren't even showing up in your Artificial Lights Dialog Box.  But, once shared, they all seem to Render well. I tested one by one.
Message 10 of 11
aRcHiTeCt.JM
... hi @winstonfoxnelson
... that's why I said to move your camera a little forward
.... but your camera wasn't inside of the wall
.... I have rendered without any problem
.... anyway FANTASTIC that you got it
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 11 of 11
572581
Community Visitor
Community Visitor
Thank you this information about sharing lights was exactly what I needed
