I created a complex model in solid form with different nodes in Revit. How can I extract the wall & roof with thickness and editable?
I created a complex model in solid form with different nodes in Revit. How can I extract the wall & roof with thickness and editable? Anyone here can quickly share their expertise? I also attached the image of model that I have created in Revit Architecture. Your input/advise is highly appreciated.
Jonathan S. Urbano
Architect
Wall and Roof by Face?
I have no idea what you're asking.  "Extract the wall & roof with thickness and editable"?  Did you create walls and roofs from the "solid form" you created "with different nodes in Revit"?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2020/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Thank you for your quick reply. I will try this, much appreciated.
