I CANT PRINT IN REVIT HHHEEELPPP
hey guys
So I am struggling and getting nervous because I have a deadline I am trying to meet...
This is very odd, but when I hit Print so that I can PDF my sheets you cannot click (and by that I mean nothing happens, not grey out) setup or preview and all of the bubbles for your options of combine or select sheets are all empty. You know how options are pre selected for you until you choose what you want?
When I went to a recovery file and tried to print it worked, so I had to redo two days worth of work to get that file current. The printing worked for a few tries and then it went back to not working. Now I am out of copies of working files and I dont know what to do!!!
Any advice??
ennujozlagam
@Anonymous hello, first of all, you didn't mention what version of revit do you have? you can try to check it HERE. thanks
I am having issues very similar to the original poster, except it does not seem to have anything to do with the file itself as the problem persists no matter what file I open.
radio buttons start out blank, but can be selected
when I hit the "select" button to select sheets/views.....nothimg happens
the files seem to work on my neighbors computer and he can print to pdf for me ....... but what a PITA!
if i just hit the "ok" button at the bottom of the print dialog it will print the current sheet.........but not formatted correctly.
using Revit 2014
Help!
Mike
