.pat file - running bond with angled tiles
1 ANTWORT 1
Nachricht 1 von 2
374 Aufrufe, 1 Antwort
Hello, I am trying to take the below lines:
*Id Series Eure Tile 2,  running bond
;%TYPE=MODEL
0,             0,             0,             0,             2
90,            0,             0,             2,             4.875,         2,              -2
and change it so that the "tiles" are actually angled at 60 degrees (they are shaped like parallelograms). When I change the angle to 60 degrees the vertical lines no longer stay within the courses, and after playing with the offsets and the shifts I haven't been able to get them back in. I can get it so that most of the pattern looks okay, but if it is applied over a large enough surface you can see that the vertical lines slowly start to creep out of the courses. The tile itself is 2"x 9.75", with 60 degree angles. Any help would be great. I am in 2016.
Tags (1)
1 ANTWORT 1
Nachricht 2 von 2
hugha
als Antwort auf: Anonymous
These tiles?
http://www.designanddirectsource.com/products/product/id-series-eure
How arranged? This is running bond:
;        Written by HatchKit for Revit
;        HatchKit for Revit (c)1990-2016 Cadro Pty Ltd
;        www.hatchkit.com.au/
;-Date                                   : 3/09/2016
;-Time                                   : 8:26:40 PM
;-HatchKit Version                       : 3.1.8.2681
;-HatchKit Output Filetype               : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*EureID
;%TYPE=MODEL
30,0,0,0,2
90.0020471178,0,0,48.5605630203,-0.111104235002,2.3094,-173.201461487
hth,
Hugh Adamson
www.cadro.com.au
