I have several views setup on a sheet I cannot select them for editing. Normally I would double click on them and be able to make edits. it seems that the titles are also gone. How can I be able to edit these views?
Thank you
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
If they are not selectable, they may be pinned and you've turned off selection of pinned elements.
The view titles could be related to the viewport type.
Sharing an example file or at least some screenshots that illustrate your issue could be helpful.
Perhaps the views are pinned and you have disabled Selection of Pinned Elements.
The View Titles are gone? You sure you didn't accidently double-click on the Titleblock and open the Titleblock Family? Yah; sounds silly but it's a possibility nonetheless.
Still can't get it...
Here is a screen shot, its all the detail views on the left:
When on your sheet turn on the little light bulb (bottom left corner) to reveal hidden elements. It is likely the view has been hidden. When you hide a view on a sheet it is still visible but you cannot select it. The indicator is that the views no longer have a view title visible.
Seems like you are on to something, the views appear hidden. Although when
I try to unhide, it is greyed out and not an option. How do I unhide the views?
@svalente9GJKH wrote:
so what would I do? I'm not seeing seeing how to unpin or unhide...
See the post where I asked you to show an addition part of your screen. Show it.
